wheel bolt pattern
Old Nov 7, 2012 | 08:56 AM
Jim-Bob's Avatar
Default wheel bolt pattern
..( I thought I just posted this but now I dont see it)
Is there a chart showing wheel bolt patterns on 1st generation to 5th gen, or are they the same..(It's-3/4" right?).. and is Firebirds with the same year the same?? THANKS
Old Nov 7, 2012 | 09:28 AM
77thor's Avatar
I have not seen any chart, but 1st and 2nd gen's are definitely 4-3/4".
Same for Firebirds.
Old Nov 8, 2012 | 05:58 AM
Jim-Bob's Avatar
Same for Firebirds.
..Thanks Thor!
Old Nov 8, 2012 | 10:33 AM
MKCoconuts's Avatar
If I remember correctly, the bolt pattern never changed from 1st to 4th gen F-bodies. 5 x 4 3/4 (120.65mm). I can not say for sure on the 5th gens.
Old Nov 8, 2012 | 12:17 PM
johan121's Avatar
Bolt pattern, lug pattern, PCD, or bolt circle refers to the diameter of an imaginary circle formed by the centers of the lugs on your automobile's wheel.
Old Nov 9, 2012 | 06:43 AM
Jim-Bob's Avatar
..thanks MK..knowing this really helps with all the nice used Camaro wheels of different generations for sale..
Old Nov 9, 2012 | 08:10 AM
It's not only the bolt pattern you need to watch for. The wrong backspacing will make or brake a fitment.
Not enough backspacing can leave you with no fender clearance, and too much can mean the wheels won't clear the back of the inner fender without using spacer/adapters.
Old Nov 10, 2012 | 06:45 AM
Jim-Bob's Avatar
..yeah..I've already gotten all that info from yall and thanks again..but there are used wheels out there for sale for other generations besides mine..Thanks
Specialist
Sep 14, 2013 07:09 PM
xkpw
Sep 25, 2010 03:55 PM
xkpw
Dec 29, 2009 11:49 AM
xxiamdrewxx
82-92 V6 Tech
Jan 29, 2009 01:29 PM
Chappie99
Jan 3, 2008 09:43 AM
