Nitrous with Stock Plugs?
Old Apr 5, 2010 | 09:27 PM
doww301's Avatar
Default Nitrous with Stock Plugs?
Can you use a 75-100 shot of nitrous with the stock A/C plugs? I was thinking about doing this, but also using a Mallory 685 to retard the timing about 2 degrees or so and to set up the rpm window for spraying, etc. I ask because I changed the plugs just a few months ago. Not fun as everybody knows, and frankly, I don't know if I really want to change them again so soon. The smart thing to do would've been to use some foresight about this, i.e. installing colder plugs at that time In case I wanted to do this later-hindsight =20/20--Doh!!. My car runs pretty cool (160-170) because of the gutted thermostat and manual fan switch, and I only race occasionally at Redding Dragstrip; but, still, I'm pretty concerned about having some nasty intake backfire or ?????????? I suppose I could answer my own thread and just start with a 50 hp shot and see what happens and then try 75 and then progress to a 100 shot if all was OK. But, on the other hand, considering this is about NITROUS, I think that it would be wiser to learn from someone else's experiences. Anyone been there, done that? Thanks in advance!
Old May 27, 2010 | 07:33 AM
z28rob18's Avatar
im a bit late on your thread but yea i spray a 100 shot one factory plugs it was ok. they highly reccomend the colder plugs but i was too anxous to get them. nothin happened. well no something happen. i roasted my clutch and decided to rebuild my entire car based around N2O lol
Old May 28, 2010 | 07:07 PM
cbr600rx7's Avatar
(Nitrous)+(stock plugs)= Bad idea
Keep in mind a 100 shot is a lot of nitrous going into a motor. You also want to get use to checking your plugs often or at least after each track day or after a few bottles. You also may want to check around and see what kind of gap some of the other LT1 guys are running on there nitrous set up. If it was me i would go one stage colder just to be on the safe side but thats just me.
Old May 30, 2010 | 12:59 PM
Speed Freek's Avatar
Running stock heat range plugs with Nitrous can cause detonation and complete engine failure, in some cases, I would get some cooler plugs, its cheap insurance. At least 1 range cooler, if your going over 100 shot go 2 heat ranges.
Old Jun 1, 2010 | 10:23 PM
blue_thunder01's Avatar
I agree with this guy...running a 100shot drop to 2steps colder..you really dont HAVE to pull any timing for 100 but its better to be safe than sorry..im not gonna pull any when i get my setup installed although i am gonna use the colder plugs
Old Jun 1, 2010 | 10:35 PM
KissMyTush's Avatar
Yeah man, colder plugs for sure!
fperezii
Apr 29, 2012 01:19 PM
hoursetraitor
Apr 25, 2011 10:14 PM
locotrician
Apr 21, 2009 06:30 PM
spisak
13
Jul 15, 2008 09:23 PM
brassknukl
12
Jun 23, 2008 04:59 PM
