2010+ V6 Tech discuss modifications to the all new 3.6L v6 here.
94 3.4 will not start
Old Oct 12, 2009 | 06:04 PM
hayslip72's Avatar
Default 94 3.4 will not start
my 94, 3.4 will not start. everything comes on no fuses blown just will not crank. not even try yo turn over. the last couple of days it done this but did start on the 2nd try. replaced the relay under the clutch and still nothing. tried to push start and it fired then died. Im at a loss. oh yeah keep blowing fuses for the air pump as well
Old Oct 12, 2009 | 06:22 PM
Failed Devices's Avatar
I would move this into the 4th gen V6 section, seeing as your car is a 4th gen.
Old Oct 12, 2009 | 11:15 PM
Nautical's Avatar
Ive had this problem may times.
The best solution would be to "Try"
and eliminate what it isn't. For
example the first time this happened to me.
It was just my Master Cylinder went bad. Key*
Then my points went bad. then i got water
on my coil wires. Then my opti went bad.
and yes my car is a nightmare to say the least.
now the fuse keeps blowing. hmmmmm
No clue sorry.
Lakatrae
Mar 29, 2014 10:59 AM
rdb357
Mar 30, 2008 08:25 AM
JTyler
Aug 31, 2007 10:21 PM
coco
Aug 13, 2007 10:33 AM
