94 3.4 will not start
my 94, 3.4 will not start. everything comes on no fuses blown just will not crank. not even try yo turn over. the last couple of days it done this but did start on the 2nd try. replaced the relay under the clutch and still nothing. tried to push start and it fired then died. Im at a loss. oh yeah keep blowing fuses for the air pump as well :(
I would move this into the 4th gen V6 section, seeing as your car is a 4th gen.
Ive had this problem may times.
The best solution would be to "Try" and eliminate what it isn't. For example the first time this happened to me. It was just my Master Cylinder went bad. Key* Then my points went bad. then i got water on my coil wires. Then my opti went bad. and yes my car is a nightmare to say the least. now the fuse keeps blowing. hmmmmm No clue sorry. :icon_doh: |
