kickdown cable help
Old Oct 31, 2007 | 03:12 PM
bdam0214's Avatar
Default kickdown cable help
How do you install/adjust the kickdown cableon a 1969 camaro 350 at the carb end. I have all the hardware installed but not sure where the slide is supposed to be in relation to the stud. I know you hold the throttle wide open and push the cable through the bracket but im stuck there. Does the slide and stud make contact all the time or only at WOT?
Old Oct 31, 2007 | 03:40 PM
Default RE: kickdown cable help
I adjust the kickdown cable to be pulled all the way out at WOT. You can open the throttle on the carb all the way by hand and see if there is any slack in the kickdown cable. If there is, adjust accordingly.
slick's camaro
Aug 13, 2012 06:25 PM
manslaughter299
Jun 4, 2012 11:08 PM
walsh4nd
Mar 16, 2008 11:25 AM
bdam0214
67-69 V8 Tech
Sep 30, 2007 11:38 PM
02renegade
May 3, 2006 01:12 AM
