Engine cranks but does not start
Old Jun 6, 2010 | 05:15 PM
  #41
gona have to play with the timing and the carb. what kind of trany is it?
Old Jun 7, 2010 | 04:01 PM
  #42
78camarodude350's Avatar
I think it is a hydro-matic 200 4-speed. i found out my torque converter is bad. the rear axle, drive line, and torque converter were all replaced.
Old Jun 7, 2010 | 06:23 PM
  #43
ahh so the converter was locked all the time. havent see that one.
Old Jun 7, 2010 | 07:56 PM
  #44
Could be an electrical issue not telling the torque converter to unlock, and not necessarily the t.c. itself.
Unless you know for sure that it is bad.
Old Jun 14, 2010 | 03:41 AM
  #45
I'm not completely sure, but i think i'm gonna replace it anyways.
What else could it be?
Old Jun 19, 2010 | 02:23 AM
  #46
The torque converter is not frozen, i put my finger in the TC and the gears move fine. but it still might freeze up when it is at high speeds. it might be the transmission but there were almost no metal shavings in the pan.
Old Jul 29, 2010 | 05:36 PM
  #47
1976camaro's Avatar
Default Paint
sorry about changing the subject but i am in the process of getting my camaro paint and i cant find a gunmetal black spray paint for some body parts. Would it be ok to use the gunmetal black spray i have for my rims on the car.
Thanks for the help
Old Aug 21, 2010 | 07:20 PM
  #48
1976camaro's Avatar
i am having the same problem with mine haha...but i dont have gas going in my carb either... try replacing ur modulator. when you take ur cap off take the rotor out also its a kinda rectangular peice usualy black. let me know if you get urs started and how
Old Aug 22, 2010 | 12:16 AM
  #49
thats a igniton modual. good idea to have a extra with screwdriver in the glove box.
Old Aug 30, 2010 | 06:42 PM
  #50
1976camaro's Avatar
im haveing the same problem i was told that its probably the timing chaing/ and or gears, also it could be your harmonic balancer... im taking my car to a buddy of mine since he has the tools and ill let you know how mine goes...let me know if you get urs started before i get back to you and what did you do to get it started
artlop
Jan 6, 2012 01:50 AM
UFL337
May 31, 2010 02:20 AM
Jackrat454
Sep 2, 2009 03:17 PM
rgviola
Jun 29, 2007 06:27 PM
opus66
Jun 10, 2007 03:49 PM
