LT1/LT4 Tech 1993-1997
Engine cranks, no start in wet weather
Old Jun 3, 2007 | 08:33 PM
rgviola's Avatar
Default Engine cranks, no start in wet weather
1994 Z-28 cranks hard but no startin wet weather. The exhaust
"coughs" as you let go of the key. Multiple trys = same disappointing result.
The motor as been turning over first try with no problem for weeks in dry weather.
The car is parked outside and of course gets wet.
Any ideas!!?? Has anybody elsehad this same problem?
Old Jun 3, 2007 | 11:39 PM
94Z28SHAKER's Avatar
Default RE: Engine cranks, no start in wet weather
sounds like a fuel pump problem, have you checked the fuel pressure?
if it only happens when its wet then make sure that there is no water dripping in the engine near the computer or near the front of the motor by the distributor(opti)
Old Jun 25, 2007 | 12:36 AM
MCP4648's Avatar
I would like to know what you find, as I have a very similar problem. Thought it was an Opti-spark problem until I replaced it and still have problems.
Old Jun 27, 2007 | 11:14 AM
rgviola's Avatar
Unfortunately I have yet to find the solution to the problem. Like you, I also have a new Opti-spark ignition system. It has been 3 weeks since the car would not start but it has also been mainly dry, no rain. I will let you know if a cause is ever determined. Please keep me updated on your situation too.
Best of luck.
Old Jun 29, 2007 | 02:51 AM
MCP4648's Avatar
Finally got my '94 Z28 running. Was hesitating, cutting out and check engine light was coming on once and a while. It finally died on the road, once before and once after the new Opti-spark. It ended up being the coolant temp sensor. I should have known, as I had same problem with my '91 Silverado. For $11 it is worth buying one and plugging it in to see if it starts. I dissected the old sensor to find the internal connections rusted through. I was not able to get any error codes out of the PCM, still trying to figure that out.
Old Jun 29, 2007 | 06:27 PM
Sometimes you need to look at the sensor output with a scan tool, & see if the readings make sense. Some silly thing like ECT sensor showing -30 temp when it 85 outside.
artlop
Jan 6, 2012 01:50 AM
78camarodude350
70-81 V8 Tech
49
Aug 30, 2010 06:42 PM
UFL337
May 31, 2010 02:20 AM
Jackrat454
Sep 2, 2009 03:17 PM
Billy Z
Aug 15, 2008 01:44 AM
