LS Series Tech 1998-2002
Alternator Removal
Old 05-06-2009, 02:01 PM
CamaroBeast98's Avatar
Default Alternator Removal
Hey everyone, I'm new to the LS1 field. I upgraded from a 1994 3.4L V6 Camaro which I gave to my little sister after I restored it. I'm having a little trouble getting my atlernator off, I was wondering if there was a special tool to get the wires off the back of the alternator. I guess you'd call them the charging wires. Any help is much appreciated, Thanks!
Old 05-06-2009, 06:29 PM
the smaller wire harness should have a plastic plugin on it. there should be a movable piece on the plugin that holds it in. if u push on this and pull on the plug it should come out. the larger wire is of corse held on with a bolt.
Old 05-07-2009, 03:03 PM
I ended up cutting the hot wire that runs to the battery to recharge it because I couldn't remove the bolt. The wiring harness didn't give me any trouble. My new alternator is coming tomorrow so hopefully it'll go on with no problems. Thanks for the help craby
Old 05-09-2009, 09:22 AM
Alternator went on without a problem, I'm mobile!
Old 05-09-2009, 09:51 AM
good deal. just in time for the weekend. on the main charge wire, did u replace the wire end or the wire itself. not a good idea to have bare wires.
Old 05-12-2009, 02:38 PM
I replaced the wire head by inserting the bare wires into the bottom of a connector head and then clamping them down. Ha yea its was ready for the weekend but I had to work doubles on both saturday and sunday so i didn't get it out much !
c_anderson180
10-12-2012 02:47 PM
WIspartan1026
06-07-2011 04:36 PM
allamericanz28
09-13-2010 04:16 PM
94z28chevy
82-92 V8 Tech
05-20-2008 03:28 PM
sPaC31
04-09-2008 06:26 PM
Quick Reply: Alternator Removal
