bad alternator?
Old Sep 9, 2010 | 12:45 PM
allamericanz28's Avatar
Default bad alternator?
Ok long story short about 2 months ago my alternator went out and replaced it with a refurbished one for o'rilleys. Ever since then the problem is when I turn the A/C on it will show on the battery gauge thats next to the oil and all those guages is draining very fast. If I sit as a stop light or another place with the A/C on for more than 2 min or so I assume it will die. Never had it happen tho. The weird thing is as soon as I move it moves back to where it should be. Also even without the A/C on, waiting in line at my brothers school for about 10 min without moving it started to go down to the red again.
Could it be I just got a bad alternator or maybe a connection somewhere. Bc I brought the battery down to o'rilleys a few days ago and it was right where it should be. Any help is appreciated. Thanks.
Old Sep 10, 2010 | 12:37 AM
how many amp alternator did you get and is the pulley on it the same one/size as the one that came off?
Old Sep 12, 2010 | 09:15 AM
Well I'm not seeing the size of it anywhere. I can tell you its an ultima 01-1751.
And yes I replaced the fully also with whichever one they gave me.
Are you thinking the pulley may be a little lose? Replace that first then do the alternator?
Old Sep 12, 2010 | 09:27 AM
Massey's Avatar
Check the wiring for the Alternator's trigger. It is the small wire going into the plug. That routs into the same part of the harness that the A/C goes into. if they are shorted it can cause your A/C Alt issues.
Massey
Old Sep 13, 2010 | 01:10 AM
thats a 102 amp alternator, shows that is ok for 98-02 camaro. i would recomend a 140 amp one. do what massey is saying. check the small exciter wire and make sure its not grounding or is partly cut.
Old Sep 13, 2010 | 09:01 AM
gfrench's Avatar
will a smaller pully increase my amps? It would make the alternator turn faster correct?
Old Sep 13, 2010 | 04:16 PM
greenarrow's Avatar
September 2009 ROTM
Yeah a smaller pulley would make more amps. You may also check the connections and make sure they are good as that could cause this also.
WIspartan1026
Jun 7, 2011 04:36 PM
94z28chevy
Jul 20, 2009 03:37 PM
lovelacci
Aug 14, 2007 12:39 AM
joeyninetoes
May 18, 2007 03:33 PM
92ChevCam305
Dec 26, 2004 03:50 PM
