LS1 6spd clutch problems
on my 98 SS about a month ago I got the dreaded sticky clutch pedal. I flushed the system and filled and bled the system with fresh fluid. this works for a week then the pedal goes again. So next I crawl under the car and look for leaks, I cant find anything and there is nothing seeping from the bellhousing. So I think its the master cylinder, I replace that and instantly have a great pedal. then a week later I lose it again.
I think that there must have been air in the system, but after 6 hours of bleeding the system I can never seem to get rid of all the air in the system.
I don't think its the throwout bearing but im not throwing that idea out.
I hope my new master cylinder isn't already bad
Any suggestions on what could be causing this?
