clutch problems
Old Oct 21, 2006 | 02:43 PM
chadimus06's Avatar
Default clutch problems
alright guys. ive got a 94 3.4L with a 5spd. the clutch isnt even a year old yet and i know its not bad. whenever i push the clutch in though it acts like its not engaging. i cant put it into gear or anything. im kinda thinkin it might be the throw-out bearing. any advice would be of some real help.
Old Oct 21, 2006 | 04:34 PM
Bubonic's Avatar
Default RE: clutch problems
How does your pedal feel?
So your cant put it into first with the car off? because you chould be able to.
You replace your throw out bearing? The clutch kit you bought was new parts right?
Old Oct 21, 2006 | 05:08 PM
chadimus06's Avatar
the pedal doesnt feel any different??? it goes into gear when the car is off but you have to start the car in neutral cuz if you start it in gear the car trys to take off even when the clutch is all the way in. i replaced the whole clutch assembly about 9 months ago. it was all new parts and everything.
Old Oct 22, 2006 | 04:05 PM
Bubonic's Avatar
You did turn your flywheel right? I dont know sorry. I am thinking there is something wrong with the hyrdaulic system.
Like is your pedal heavy or light or spongey? How is your clutch fluid? When you put in your throw out/release bearing you put both of the fork prongs on the inside right?
BlueKitsune
Jul 22, 2020 08:55 AM
blazelt1
Mar 12, 2009 06:10 PM
BALarcade
Feb 2, 2009 11:20 PM
wildman1
Oct 24, 2006 11:51 PM
RSZ28SS
Oct 23, 2006 04:20 PM
