clutch problems
I have a 95 3.4, I have replaced the clutch and the slave. Then i had nothing, so i replaced it agian and the master. still it broke the stapes holding it both times but still wont go into gear. What could it be could the fork have to much play. I really need this car going like a week ago.
when you say you replaced the clutch did you replace the throwout bearing?? pilot bearing?? pressure plate?? are you 100% sure the disk is in the right way?? is the hydraulic system bleed completely??
I had a shop put it in, And they say it was done right. But I am going to rip it out tonight. And i tried to bleed the original system. But the master was bad, so i replaced it. The instead if messing with the old slave I got one for a 92 3.1 bleed it the petal is stiff and I watch it and it is working. When the car is running it wants to move when you try to put it in gear. I dont know it is a pain doing it by yourself that why I took it to the shop. But you never get your moneys worth anymore.
Well it was the disk, just finished it. But the car is idling rough I know it needs a tune up. And the a/c keep's kicking on and off. Is there any normal problem they all have its got the 3.4. maybe vac leaks because the break pedal is real stiff too.
