LS1 6spd clutch problems
Old 12-17-2014, 09:09 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
Default LS1 6spd clutch problems
on my 98 SS about a month ago I got the dreaded sticky clutch pedal. I flushed the system and filled and bled the system with fresh fluid. this works for a week then the pedal goes again. So next I crawl under the car and look for leaks, I cant find anything and there is nothing seeping from the bellhousing. So I think its the master cylinder, I replace that and instantly have a great pedal. then a week later I lose it again.
I think that there must have been air in the system, but after 6 hours of bleeding the system I can never seem to get rid of all the air in the system.
I don't think its the throwout bearing but im not throwing that idea out.
I hope my new master cylinder isn't already bad
Any suggestions on what could be causing this?
Old 12-18-2014, 05:40 AM
Everett#2390's Avatar
I have made a alum plate larger OD then the reservoir top, drilled a hole in the middle, put a neoprene gasket under the plate, and use a hand vacuum pump to suck out the air.
Might help.
lifteds10man
02-01-2012 09:29 PM
BALarcade
02-02-2009 11:20 PM
highroller814
82-92 V8 Tech
04-20-2007 10:56 PM
chadimus06
10-22-2006 04:05 PM
stevo5662
LS Series Tech
04-06-2006 12:50 AM
Quick Reply: LS1 6spd clutch problems
