Help, cant read codes on 1994 lt1 obd1
Old 06-22-2011, 09:35 PM
cmorgan's Avatar
Originally Posted by craby
mine will only scann if i put it in as a 92. have you tried entering a different yr to see if it would work.
I tried 93 and 95. I try 92 (88 89 90 91 92) tomorrow. I was messing around with the different years and inputted something to the effect of a 93 truck and it locked up for a min and came back with i think 43 codes. But if I remember correctly when I scanned it years ago, the fans would kick on when you powered up the scanner.
anyways i will try the other years and report back.
Thanks for the help!
Old 06-22-2011, 10:47 PM
yes the fans come on when it goes into diagnostic mode. i called the company rep and the guy took me through a few years and he had me do a truck one. nothing happened until we tried the 92. i would think a 94 would be a 93 94 95. could depend on the scanner though.
Old 06-23-2011, 07:21 PM
cmorgan's Avatar
92 worked!!!!!3 codes 23, 27,28.
And I found those codes lead to a blown 20 amp air pump fuse in the engine compartment. I replaced it a week or so ago and now its blown again. I just replaced it again and put 40 miles on it, so far so good. no engine light and the fuse is still good.
Thanks for your help....
Old 06-23-2011, 11:38 PM
23 is a low reading at the intake air temp sensor, 27 and 28 are quad driver codes. strange that the air pump would cause any of them. my air pump kept blowin fuses, the pump/fan was shot. scan it again in a day or two and see if its still throwin codes. low temp on the iat sensor can cause fuel consumption issues.
Old 08-20-2011, 01:28 PM
d1trubo's Avatar
I'mhavng the same problem with scanners, does the v6 have a air pump? mine has the fuse and the relay but it has a wire connector that is laying next to the fuse block under the hood with two red wire nd one black one thats for the pump right? engine stalls while idling checked all sensors and found the tpc to only 4.25 volts at wot. any ideas
Old 08-20-2011, 02:49 PM
whats it read at idle? are the volts jumping around when you slowly raise the throttle to wot or raising smooth?
Chaotic94
01-30-2013 01:34 PM
contryboy
09-14-2009 11:34 PM
aleksandr
01-01-2008 12:39 PM
MCP4648
06-29-2007 06:29 PM
golfballs
01-28-2007 06:43 PM
Quick Reply: Help, cant read codes on 1994 lt1 obd1
