Engine Problems
Old 05-04-2016, 04:01 PM
Don80camaro's Avatar
Default Engine Problems
Just joined the sight because i am in need of some help. Getting my 80 Camaro out and running for the season and it has developed a weird symptom since i put it away last year for the winter. when I floor it at around 4k RPMs it starts to break up and misfire, but if i were to not open the secondaries and just allow the engine to accelerate on the primaries it doesn't do it. I have put new plugs and wires in, re-built the carb, and replaced the spark plugs. when i did that it seemed to be better for about one day, but now it is back. Any help would be greatly appreciated.
Engine info:
-350
- 650 holley carb
-t5 5 speed
- the engine was re-built in 2013
Old 05-04-2016, 06:33 PM
Check for corrosion on the contacts inside the distributor cap and rotor. Could have accumulated some crud in there.
Old 05-07-2016, 10:04 AM
Thanks, I just got a chance this morning to get in the cap and inspect, and you were right there was a bit of crud on the points. So I cleaned them using an electrical cleaning spray, and then hit them with a bit of sand paper. Reassembled it and try to fire it up but I get nothing now. I don't quite understand what could possibly wrong with it I didn't change anything just took it off and put it back on.
Old 05-08-2016, 02:02 PM
Everett#2390's Avatar
Since an '80, and it is equipped with HEI, ensure the center button has not fallen out between coil and rotor.
mp734
11-06-2013 11:54 AM
Vandee
05-01-2013 05:57 PM
IZZY1967RS
06-19-2008 10:29 PM
jdubs1813
11-12-2007 04:16 PM
Nightmaro
10-07-2007 10:33 PM
Quick Reply: Engine Problems
