how wide can i go?
Old 05-30-2016, 06:44 PM
Rebuilt57's Avatar
Default how wide can i go?
Can I install 255/60-15 on the rear of my 1969 Camaro without using air shocks?
Thanks for the help.
Old 05-31-2016, 03:11 PM
77thor's Avatar
It will all depend on the backspacing of the wheels you're using.
Old 05-31-2016, 03:22 PM
Rebuilt57's Avatar
Default How Wide Can I Go
Thanks for the reply
I am considering American Racing Torque Thrust VN109 which has 3.75 back spacing..
Old 10-11-2016, 01:22 PM
MikeJ67's Avatar
Hey guys,
Quick question (aren't they all?) I've got a '67 and I'm getting ready to do the suspension thing. I'd like to drop the car 2" up front and 1.5"-2" in the rear. It's an everyday type car (usually on the weekends) and I have a chance to by a nice set of tires which appear to be the "largest" things to fit under the fenders, but in all of the reading I've been doing, "most" of the threads are for "stock" height suspension. How much of a difference does it make with a 2" drop all around?
I plan on going with 4 whl disc brakes. I know the 17x8 (5"bs - 245/40) seem to be the number up front, and the 17x9.5 (5.5" bs - 275/40) seems to be the number in the rear. I do NOT want to rub with this car. - - - - Now I'm reading with the tubular upper/lower control arms that you really need 18s to clear the ball joints?? True?
Thanks
Old 12-18-2016, 02:25 AM
MikeJ67's Avatar
Just checking in again. So the numbers we all hear about are for "stock" suspension, but what about a LOWERED suspension?
I guess I'll make all of the necessary changes and "then" take all new measurements to see just what I can stuff under the fender lips.
Old 01-22-2017, 02:25 PM
flat tire's Avatar
actually pretty wide
Old 04-25-2017, 09:14 PM
57Vette's Avatar
Current 255/60-15 rears just fit on the 8" Rally wheels. Only get a slight kiss on one side when making a RH turn into my steeply angled driveway.
Still debating on whether to go Cragar or something bigger. There's something beyond classic with the cragars. I found a place that will either cut or re-hoop them too. I would like a slightly deeper look than the 8" rears, maybe 9" if I could figure out a backspace that would keep the tire inside the fender and not hitting the shock LOL!
Muzza
01-22-2017 12:44 PM
2011silvercamaroguy
05-28-2011 12:01 AM
Netherstorm
08-12-2007 12:52 PM
ninetysixyenko
06-29-2007 02:57 PM
Lil_427
07-06-2006 08:26 PM
Quick Reply: how wide can i go?
