oilpan
Old 01-08-2011, 07:23 PM
hotrods1's Avatar
Default oilpan
Can you get the oil pan off on a 68 with a 396 with the engine in the car?
Old 01-09-2011, 02:46 AM
carguy68ssrs's Avatar
Yes if you undo motor mounts, still not easy
Old 01-09-2011, 09:02 AM
hotrods1's Avatar
Default oil pan
thanks, I have to put in a new rear seal, I know it would be alot easier to pull the motor but I'm tring to do in my driveway without my HOA getting all over me. I know I will have to jack the engine up but it still looks like it will be tight. I've done it with a small block, but was not sure with a big block.
Old 01-09-2011, 06:03 PM
hotrods1's Avatar
well,your right you can but I had to remove the starter and passenger side header, which allowed the pan to roll up and out, also had to rotate engine a couple of times but got her done and back together.
timopajala
67-69 V8 Tech
05-26-2014 10:37 AM
kyphur
07-19-2012 11:21 PM
tattooedtrash
05-13-2010 09:55 AM
tb04512
08-19-2006 12:37 AM
Quick Reply: oilpan
