Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
new brakes?
Old Jan 18, 2008 | 02:02 AM
camarohardcore's Avatar
Default new brakes?
i have a 96 base model, and i really want to get rid of those UGLY rear drum brakes and possibly the front ones, with a spiffy new set. where do i find the parts? and what do you guys think would be good for my car?
Old Jan 18, 2008 | 06:45 AM
bluovlh8er's Avatar
Default RE: new brakes?
um........ well for the front you could always paint them (black?) thats what i do.... and for the rear..... it has been done, you just got to run all the brake lines, and get all the hardware. what would be easy is to go to a junk yard and get the whole rear end out of a z28.... (posi andhigher gears too, 3.32 or 3.42 instead of 2.73 or 3.08 [:'(]) then just run the lines.
Old Jan 18, 2008 | 03:36 PM
blackz87's Avatar
Find another 4th gen rear with Disc brakes and Limited Slip & 3:23 or 3:42 gear ratio and bolt it in.Nothing has to be changed on your car. These rears are cheap and should be in the range of $200/300. If you can do the work yourself, great.
Old Jan 19, 2008 | 12:26 PM
bluovlh8er's Avatar
duh, its what i just said.
Old Jan 19, 2008 | 01:09 PM
blackz87's Avatar
ORIGINAL: bluovlh8er
You may of ment the same thing but it didn't come out very well in your post. "um...well" no drums in the front to paint.
Old Jan 21, 2008 | 04:42 PM
haha. word. i was under the impression that you could buy a set of new brakes and everything you need aftermarket. but i'm digging the finding the rear end thing. i'll check around my local junkyards and stuff. thanks dudes.
Old Jan 21, 2008 | 10:40 PM
1969 SS's Avatar
ORIGINAL: camarohardcore
you totally can buy everything you need in the aftermarket, but as you've said you have a "base" Camaro, you probably wouldn't want to spend the bucks to do that type of upgrade, and you would also have to pull your axles to change out your backing plates
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
importmd
Mar 17, 2008 09:43 PM
92camaroRS
Jun 1, 2007 09:31 PM
coprunr
May 16, 2007 04:40 PM
