Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
My tail lights
Old Mar 19, 2008 | 05:47 PM
73camaroSS's Avatar
Default RE: My tail lights
Thanks for telling me my answer wasn't stupid lol,I agree with bill if there is rust and corsion (sorry im a bad speller)the light will not get the power it needs to light up but if that dosent work then maybe a wire was pinched our cut when it was damaged, But i have never worked on a 4th gens tail lights, Cause i drive a old *** camaro and nothing is sealed from the water and dust, But i would give it a try and if i dosent work just make a nother post LOL. Good luck with the camaro.
Tony
Old Mar 19, 2008 | 07:45 PM
CMRO GRL's Avatar
May 2008 ROTM
Thanks Tony, good luck to you too
Old Mar 19, 2008 | 08:49 PM
importmd's Avatar
i agree, drill four small holes in each light, it will drain the water and let the lights breath and not get foggy.
Old Mar 19, 2008 | 10:15 PM
th3po1son's Avatar
can u open it, dry it out, and then put it back together and seal it with silicone? or will that not work?
Old Mar 19, 2008 | 10:20 PM
CMRO GRL's Avatar
May 2008 ROTM
well, it happened to both sets of lights... so, either all after market lights are made poorly, or it is really the socket or whatever. i doubt its the seal
Old Mar 20, 2008 | 03:56 AM
6v49der's Avatar
Get some OEM lights if it really bothers you that much, Ive never seen OEM lights leak like that unless they are cracked.
Old Mar 20, 2008 | 06:35 AM
SpecterGT260's Avatar
Ninja Administrator
silicone is messy and unless youre really experienced you wont like the results
Old Mar 21, 2008 | 03:19 PM
bill12690's Avatar
ORIGINAL: red94v6
thats the problem with mine.. for some reason the reverse lens started to come out a little, like the seal was bad. I had to take it out and reseal it but i guess i'll need something a little better.. i used some silicone, and it didn't look bad, but it didn't completely do the job. Hopefully i'll jsut buy some newer ones though..
98Z28ImportSlayer
Mar 16, 2012 09:07 AM
CamaroKidd
May 11, 2011 11:25 AM
RS camaro
Sep 8, 2010 01:00 PM
vXIcetreyXv
Oct 23, 2009 07:25 PM
bodykits
Jul 1, 2009 09:52 PM
