Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Fixing a ding with bondo
Old Mar 27, 2006 | 06:48 PM
xc|bandit's Avatar
Default Fixing a ding with bondo
Hey all i have a ding in a door that i tried to repair with bondo.I sanded down to bare metal,applied the filler.Well i started shaping with 100 grit,then went to a 220grit and finalized with 500 grit.The problem is when i put primer on it i can still see the shape of the filler under the primer.My question is,do i need to use different sand paper? for some reason i just cant seem to get it feathered.
Old Mar 28, 2006 | 07:43 PM
mattvogt's Avatar
Default RE: Fixing a ding with bondo
try applying a new coat of primer. also, apply your paint ontop and see how it looks. You should beable to featheredge with the 500 grit paper. I dont know why its not looking right. Use the sandable primer and coat the surface again. then sand, the prime/fill with the primer filler. sand and continue untill it goes on smothe.
Old Mar 28, 2006 | 09:56 PM
xc|bandit's Avatar
ok thx...i just got done sanding some more and shot some more primer...let you know how it looks
Old May 15, 2006 | 03:26 AM
wig's Avatar
wig
I work as a painter at a body shop.If I had to take a guess I'd say the bondos not feather out enough.Body man send me stuff like that all the time.
Old May 21, 2006 | 07:46 PM
mattvogt's Avatar
Yea, thats why you should use the spot putty to fill in between the bondo and the good body. That way it is straight and smothe.
Good luck
Sniekamp
Dec 10, 2012 10:15 AM
richard.nelson100
Apr 17, 2012 01:45 PM
1980rscamaro619
Jan 9, 2008 11:32 AM
94Red
Jul 24, 2007 11:31 PM
ScottD
Oct 27, 2006 01:27 AM
