Ding Ding (pause) Ding
Old Apr 17, 2012 | 12:43 PM
richard.nelson100's Avatar
Default Ding Ding (pause) Ding
94 3.4L.....new sensors all around....all AC Delco except the O'Reilly throttle position sensor which has been replaced 3 times in 4 months. I reset the computer one last time to bring the idle from 2200 RPMs back down to 950 rpms. Drove it to AC Delco...parked....got the new AC Delco tps. Put the keys in the ignition to leave.....then got a Ding Ding (pause) Ding. Do you think its just the junk oreilly tps that hadnt been replaced yet....or what does that ding sequence mean? Thanks for the input! By the way....no ses light.
Old Apr 17, 2012 | 01:45 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Did you zero the tps when you installed it? The dings are normal. To zero the tps turn the key to on, press the pedal down to the floor 5 times and then turn the key back off and then turn the car on. It should be set.
mpr21290
Mar 31, 2015 01:37 PM
machine1999z28
LS Series Tech
Nov 14, 2009 10:12 PM
94Red
Jul 24, 2007 11:31 PM
xc|bandit
May 21, 2006 07:46 PM
