Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Body Guys Help...
Old Apr 20, 2008 | 12:08 AM
bluez's Avatar
Default Body Guys Help...
Ok.. here is the problem.. its too late and dark to get pics... but on the drivers side rear quarterpanel right where the window ends and goes up the Piller .. the (what i would cal a wrinkle) is right on the top next to the corner of the rear hatch on the drivers side. it is pushed in like something fell on it.. but no marks its more like a wrinkle in the metal fender.. (lighter weight with only3 pieces on metal on the whole body )
ill get pics if i can .. the car is blue and it hard to see in the day.. a friend said it was from launching hard.. i havent got my frame connector on yet..
waiting for builderto get a spot. then i got some go-fast goodies too
thanks in advance if u have any help for me
Old Apr 20, 2008 | 11:28 AM
Default RE: Body Guys Help...
It sounds like the area you're describing is in the sail panel. If you've been doing some hard launches, that can cause a wrinkle on the drivers side. Under severe torque, the left front of the body wants to lift up more than the right, which causes the wrinkle in back. Preventing body twist (and the after-effects) is one of the main reasons for wanting to use frame connectors. It would be a good idea to have a frame shop check your car for any body twist because once you weld in the frame connectors, that's where she stays.
Old Apr 20, 2008 | 12:37 PM
bluez's Avatar
Thanks.. that is excatly where the wrinkle is.. Again thanks.. ill take it to my freinds body shop to have him look at it..
2nd Question.. Can it be fixed with out painting? there is a paintless dent repair guy that buys from my store.. i seen his work its pretty darn good.. should i try on this spot..or will it make it look worse..in your opinon .. since i havent show u pic yet..
Old Apr 21, 2008 | 01:11 AM
I have had a couple of my cars that had bad hail damage and had them repaired by Dentless Repair.I have also watched them glue some special plastic rods to the painted surface and pull a dent witha little dent puller, then they remove the rodwith a solvent and do their massaging. It's really amazing what they can do, you can't even tell. That's where I would take it to get it fixed because you really don't want to break into the factory paint job and fix it externally if you can help it. But be sure to get the car re-tweaked before getting the wrinkle fixed. And go easy on the right foot till the frame connectors are in.
njmike
Jun 23, 2013 10:09 PM
CamaroNut
General Racing/Tech
Oct 15, 2009 12:12 PM
taylor_b92
Aug 18, 2008 02:48 AM
coprunr
VS
18
May 6, 2007 11:45 PM
ScottD
Nov 8, 2006 09:01 PM
