Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
69 wheel and tire ?
Old Jan 17, 2008 | 01:08 PM
mt69z28's Avatar
Default 69 wheel and tire ?
I have a 69 Camaro, currently factory ride hide without any suspension modifications, I found a set of ROH RT wheels that I would like to buy for my car. However, I am unsure if they will fit. From what I have gathered the factory wheels were 15X7, 5 on 4 3/4 with a back spacing of 4.25" in the front and 4.9" in the rear. The new wheels I would like to run are (same bolt pattern) 18x10 w/ a 5.5" backspacing (rear) and 18x9 w/ a 5" backspacing (front)
The second question is in regards to the tires. I have (on there now) 295/60/15 on 15x8(rear) and 235/60/15 on 15x8 (front). Which are 28.9" tall x 11.6" wide (rear) and 26.1" tall X 9.3" wide (front). I would like to run 295/45/18 (rear) and 245/45/18 (front). Which are 28.5" tall x 11.6" wide (rear) .4" shorter than what I have and 26.7" tall x 9.6" wide (front) .6" taller and .3" wider than what I have.
I know I can measure the car and see if it will work but it is in storage right now. I would like to know if anyone knows of any foreseeable problems with the fitament of this wheel/tire combo and if so how much or what type of work would need to be done to allow these? Or if any one had done something similiar and if they did any modifications, how extensive they were, etc...?
Thanks, Mike
Old Jan 19, 2008 | 11:44 PM
1969 SS's Avatar
Default RE: 69 wheel and tire ?
I answered this in your other post. when asking questions, you should only stick with one post on the same subject. it keeps things less confusing
juarch328
Aug 19, 2011 02:53 PM
kissbally78
Dec 26, 2010 09:43 PM
rick71ss
Sep 19, 2008 08:51 AM
mt69z28
Sep 12, 2008 12:17 PM
Roadman
Oct 16, 2006 11:46 AM
