killed an honda accord and mitsubishi 3000gt
#21
ORIGINAL: BigNic
these are the numbers listed on msn autos.com directly from mistsu so if you are feeling that you know the engines that they put out better than they do you may want to go apply for a job becuse they likey need sombody to clear that up for them
ORIGINAL: 3000gtskickass
dont know where you getting your info from... all base models 3000gts up to 97 (3rd gen) have the dohc 6g72 222 hp 205 tq same exact engine used in the sl
ORIGINAL: BigNic
this is what you could be dealing with
![](https://fp.images.autos.msn.com/images/spacers/spacer.gif)
Base
SL
VR-4
Standard Engine
3.0L 161 hp V6
3.0L 218 hp V6
3.0L 320 hp V6
Horsepower
161 @ 5500 RPM
218 @ 6000 RPM
320 @ 6000 RPM
Torque (lb-ft)
185 @ 4000 RPM
205 @ 4500 RPM
315 @ 2500 RPM
and as stated by others there heavey so Base and SL are going to be in the 3.8s range as far as the VR-4 its not gonna blow the LT1 away its gonna be darn close if you convince him to run from a low roll is were you best shot is LS1 take out the VR-4 without to much trouble my opinion
Base
SL
VR-4
Standard Engine
3.0L 161 hp V6
3.0L 218 hp V6
3.0L 320 hp V6
Horsepower
161 @ 5500 RPM
218 @ 6000 RPM
320 @ 6000 RPM
Torque (lb-ft)
185 @ 4000 RPM
205 @ 4500 RPM
315 @ 2500 RPM
![EEK!](https://camaroforums.com/forum/images/smilies/eek.gif)
#22
ummm
1. there is no such thing as semi false somthing is either true or false....
2. these numers are coming directly from mitsu
3. next time if you going to call out someones fact from a know source you may want to have a source of your own to referance....
4. gtfo
5. trolls suck
6. i think everyone here can do without anymore of your input
7.k thnx
4. gtfo
5. trolls suck
7.k thnx
#23
my source is the truth. yours, however parts of it are true, do some more reasearch u v8 driving egotistical ****
and i doubt them stats r from mitsubishi because they wouldve stated that from 1991 - 1997 base models had 3.0 dohc 222 hp/205 tq and from 1997 - 1999 base models had 161 hp/185 tq so until u do more research on this car that u DONT KNOW NOTHING ABOUT how about u try shutting your mouth ya *** ![Smile](https://camaroforums.com/forum/images/smilies/smile.gif)
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
#26
