Gear shifter jumping
I've got an 84 Z28 with a 305 and standard 5-speed transmission ... front to back it is all stock.
Last night on the way home, I noticed the gear shifter jumping up a few inches (noticeable would be an understatement) whenever I 'get on it' in first from a start and/or when I shift quickly from 1st to second.
My first thought would be the transmission mount but wanted to see if I needed to look elsewhere.
Thanks
Thanks
its very easy to do. theres 4 bolts on the crossmember, 15mm heads. theres 1 on the mount to the crossmember, and should be 2 on the trans. you could it without removing the crossmemeber, but its much easier to get to the trans bolts with it out of the way.
