Gear shifter jumping
Old Oct 23, 2010 | 12:34 PM
bulldogrsp61's Avatar
Default Gear shifter jumping
I've got an 84 Z28 with a 305 and standard 5-speed transmission ... front to back it is all stock.
Last night on the way home, I noticed the gear shifter jumping up a few inches (noticeable would be an understatement) whenever I 'get on it' in first from a start and/or when I shift quickly from 1st to second.
My first thought would be the transmission mount but wanted to see if I needed to look elsewhere.
Thanks
Old Oct 23, 2010 | 02:19 PM
Yep, the tail end of the transmission will get pushed up by the torque arm if the trans mount is torn.
Old Oct 23, 2010 | 03:09 PM
Thank you for the reply.
That is what I thought ... is it an 'easy' fix or is this something I'll want to have a professional do?
Also ... is it driveable this way without any serious/permanent damage?
Old Oct 24, 2010 | 09:26 AM
Yes. it's an easy fix, google a how-to if you need to.
And yes, you can still drive the car, as long as you take it nice and easy on the throttle.
Old Oct 24, 2010 | 07:17 PM
microkid's Avatar
March 2011 ROTM
Technical User
its very easy to do. theres 4 bolts on the crossmember, 15mm heads. theres 1 on the mount to the crossmember, and should be 2 on the trans. you could it without removing the crossmemeber, but its much easier to get to the trans bolts with it out of the way.
Clod_Z28
Dec 10, 2009 08:16 PM
bd92rs
Feb 11, 2009 12:33 AM
250motorsportz
Jul 19, 2008 12:03 AM
soulvoid
Feb 10, 2008 06:00 PM
thebandit110
Mar 13, 2007 01:54 AM
