2011 Ride of the Year
8 Attachment(s)
This is for all the marbles..Who is the CamaroForums ride of the year??
Its all coming down to the final 12 who won from January through December Ride of the Month. There are no nominations, just voting on this one... Feel free to post new photos of your rides for those listed...and good luck to all!! Attachment 22236 http://img822.imageshack.us/img822/6331/dsc0027pq.jpg http://a2.l3-images.myspacecdn.com/i...1b765853/l.jpg http://i1018.photobucket.com/albums/...260004_1_1.jpg Attachment 22237 Attachment 22238 Attachment 22239 Attachment 22240 Attachment 22241 Attachment 22242 Attachment 22243 http://www.orocker.com/rotm/o7.jpg |
Voting is now OPEN
3 Attachment(s)
Originally Posted by Cheeks
(Post 596458)
woooooooooo
good luck everyone For more of my pics, check my sig! |
Congrats to all who made it this year, proud of you ;)
7 Attachment(s)
Good luck to all. Here some more pics of my car.
LS1 Install My 1977 Camaro Specs Attachment 22036 Attachment 22037 Attachment 22038 Attachment 22039 Attachment 22040 Attachment 22041 Attachment 22042 |
jerhofer is the man,got my vote
Originally Posted by bowtieguy
(Post 596799)
5 Attachment(s)
vote for the red one, hay how come i gets the pink line???? no fair.
Attachment 21995 Attachment 21996 Attachment 21997 Attachment 21998 Attachment 21999 Intake by elliotts port works fully ported enlarged runners 58mm tb opening 58mm bbk throttle body LT1 LE2 heads by elliotts port works manley 2.00/1.56 6000 series valves patriot gold extreme springs (155 lbs seat and 400 lbs open) 205 cc intake port flow about 275/190 CFM bullet racing cam grind #CLT276/281-12HR 223/230 .565/.565 112 separation single roller timing chain with gears aluminum billet oil pump drive housing ARP 134-7103 7/16 rocker studs Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100 comp cam 1305 roller rockers 1.6 7/16 pro magnum tpis performance roller lifters GM performance composition head gaskets .028 compressed thickness gm performance oil pump 5.5 qt moroso oil pan arp oil pan studs arp main bearing studs moroso oil pump pickup rpc valve covers kooks 1 3/4 x3 headers jethot coated kooks catted y pipe jethot coated corsa cat back with 3 1/2in. double outlets. patc level 3 transmission with the raptor drive and and power gear upgrades patc 5x power raptor lockup 2000 stall torque converter with a torque multiplication rate of 2.5. derale 7 1/2x11 transmission cooler spohn driveline 373 gears koni double adjustable struts koni adjustable shocks spohn panhard bar spohn crossmember mounted torque arm spohn shock tower brace spohn rear lower control arms spohn subframe connectors powerstop slotted & drilled rotors hawks ceramic pads strano braided brake lines strano hollow 32mm front sway bar strano 22mm adjustable rear sway bar Wheels/Tires Modifications: Front 17x8.5 Billet 245x45 Back 17x11 Billet 315x35 white face gages kenwood kdc-x994 kenwood kfc-c1739ie 6-3/4" 3-way speakers pioneer ts-a1782r 6-3/4" 4-way speakers mtx t-form 93-02 camaro black w/10" sub |
My vote's in, it only took a pinch
| All times are GMT -5. The time now is 07:47 AM. |
