View Poll Results: 2011 Ride of the Year
Bandit
7.41%
73Z
7.41%
Microkid
3.70%
Craby
3.70%
MileHighSS
0%
tazinhawaii
22.22%
jerhofer
14.81%
cheeks
3.70%
chaotic94
3.70%
Socom
11.11%
BudBrown
3.70%
Orocker
18.52%
Voters: 27. You may not vote on this poll
Old Dec 14, 2011 | 11:10 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default 2011 Ride of the Year
This is for all the marbles..Who is the CamaroForums ride of the year??
Its all coming down to the final 12 who won from January through December Ride of the Month. There are no nominations, just voting on this one...
Feel free to post new photos of your rides for those listed...and good luck to all!!
Old Dec 26, 2011 | 10:58 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
Voting is now OPEN
Old Dec 26, 2011 | 12:47 PM
Cheeks's Avatar
August 2011 ROTM
woooooooooo
good luck everyone
Old Dec 26, 2011 | 01:22 PM
BudBrown's Avatar
November 2011 ROTM
Ride of the Month Director
Originally Posted by Cheeks
woooooooooo
good luck everyone
Ditto! Hope everyone had a wonderful year and a happy holidays
For more of my pics, check my sig!
Old Dec 26, 2011 | 03:38 PM
iLL95's Avatar
I Like to Party
Super Member
Congrats to all who made it this year, proud of you
Old Dec 26, 2011 | 05:42 PM
jerhofer's Avatar
July 2011 ROTM
Good luck to all. Here some more pics of my car.
LS1 Install
My 1977 Camaro Specs
Old Dec 28, 2011 | 05:57 PM
bowtieguy's Avatar
July 2009 ROTM
jerhofer is the man,got my vote
Old Dec 28, 2011 | 07:01 PM
jerhofer's Avatar
July 2011 ROTM
Thanks.
Old Dec 28, 2011 | 07:07 PM
vote for the red one, hay how come i gets the pink line???? no fair.
Intake by elliotts port works
fully ported
enlarged runners
58mm tb opening
58mm bbk throttle body
LT1 LE2 heads by elliotts port works
manley 2.00/1.56 6000 series valves
patriot gold extreme springs (155 lbs seat and 400 lbs open)
205 cc intake port flow about 275/190 CFM
bullet racing cam grind #CLT276/281-12HR
223/230 .565/.565 112 separation
single roller timing chain with gears
aluminum billet oil pump drive housing
ARP 134-7103 7/16 rocker studs
Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100
comp cam 1305 roller rockers 1.6 7/16 pro magnum
tpis performance roller lifters
GM performance composition head gaskets .028 compressed thickness
gm performance oil pump
5.5 qt moroso oil pan
arp oil pan studs
arp main bearing studs
moroso oil pump pickup
rpc valve covers
kooks 1 3/4 x3 headers jethot coated
kooks catted y pipe jethot coated
corsa cat back with 3 1/2in. double outlets.
patc level 3 transmission with the raptor drive and and power gear upgrades
patc 5x power raptor lockup 2000 stall torque converter with a torque multiplication rate of 2.5.
derale 7 1/2x11 transmission cooler
spohn driveline
373 gears
koni double adjustable struts
koni adjustable shocks
spohn panhard bar
spohn crossmember mounted torque arm
spohn shock tower brace
spohn rear lower control arms
spohn subframe connectors
powerstop slotted & drilled rotors
hawks ceramic pads
strano braided brake lines
strano hollow 32mm front sway bar
strano 22mm adjustable rear sway bar
Wheels/Tires Modifications: Front 17x8.5 Billet 245x45
Back 17x11 Billet 315x35
white face gages
kenwood kdc-x994
kenwood kfc-c1739ie 6-3/4" 3-way speakers
pioneer ts-a1782r 6-3/4" 4-way speakers
mtx t-form 93-02 camaro black w/10" sub
Old Dec 28, 2011 | 11:27 PM
iLL95's Avatar
I Like to Party
Super Member
My vote's in, it only took a pinch
