Back-seat Stingray
#101
Might want to seriously re-think that plan....just sayin. It's not likely to end at you just doing a frame cleanup, paint the frame, and body reinstall. You can clean up a good portion of the frame with the body still on. I did mine with the car up on a lift.
#103
No, but yeah I'm sure you'll break something you don't want to. I've just seen a frame off turn into a can of worms before. Oh well, as long as everything is out in the open, might as well replace the rear bushings cuz they're a little sloppy, and then the rear wheel bearings, and look the rearend is leaking, and the brake lines are rusty, and the front suspension could need replacing, and then.... Meanwhile, two years later...... Heck, even some frame on projects drag out way too long. Like, my current one for instance.
#107
OK I have decided to do the frame off. Once I finish the camaro I will start taking the vette body off. I got my wiring harness but can't pick it up til Monday. So all weekend the camaro is my project. Pics will be taken. Lots of them!
