Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Twin Turbo V6
Old Apr 18, 2008 | 09:08 AM
  #21
SpecterGT260's Avatar
Ninja Administrator
Default RE: Twin Turbo V6
except the fact that you would need internals similar to the regals in order to boost it to those levels. displacement means very little to a motor. its about whats inside. the camaro 3.8L is far from bulletproof. it will grenade under low boost conditions pretty easily without an upgrade to the bottom end
Old Apr 18, 2008 | 08:27 PM
  #22
MusicMan's Avatar
The Jazz Man
Wow, didn't know that. I need to keep that in mind when I build my V6. I believe that they are a stronger engine than other comparible V6's. You can build 'em to take a heck of a beating, but it is not cheap. I've been planning to build a nitrous engine for a very long time. But I had the bonneville back then, now I've got a camaro with the same engine. I guess the 3.8 is not as rock solid as I thought. Gonna have to do some work on the bottom end first.
Old Apr 18, 2008 | 09:11 PM
  #23
BigNic's Avatar
4' 11" 117 lbs of fury!
from what ive read camarov6.com you can genneral get close to 10 lbs without to much upgrade....again i have a feeling sombodys gonna blast me on that but that is what my memory is telling me. but without continueing to re-enforce the engine at that amount of boost will not grenade it per say but will greately shorten the engines life.
96V6Camaro
Oct 11, 2021 09:41 PM
tt383lt1
Dec 19, 2011 05:31 PM
simperfi-rs
82-92 V6 Tech
Feb 3, 2011 07:55 PM
CamaroCraz22
Jul 31, 2007 06:20 PM
