Turbo Help
RE: Turbo Help
Haha.. well.. I would.. if those weren't also rare. It took me a year and a half to find a camaro within my own city. I found 2 in a city 2 hours away, and they are both 95 Z28s priced at over 13,000
#20
RE: Turbo Help
ORIGINAL: SpecterGT260
you are basically screwed if you think youre gettin away light.
you could do a single kit (a bi-turbo is overkill on a stock motor) and boost about 6psi, but that wouldnt do much for you, maybe give you 25-30% power. but u could do it.
you would be safe as long as the car gets a proper tune. if you dont want to send the car to a shop to tune it u might as well just stick to boltons.
i dont know what the stock injectors are, but you will probably need new injectors, which will come with your kit most likely, and a fuel pump which should also be included. assuming you get a kit for this.
youre lookin at probably $4k when this is all said and done for a very basic kit.
