charger and nitrous
i have a nitrous kit not yet installed its sitting in my garage and i would like to put it in plus a super charger not yet purchased but saving up for one, can i do both or will this not work?
Those will actually be complementary items. As the air is compressed by the supercharger, it heats up. Nitrous has a cooling effect to make the air more dense. So if it is a wet shot, you can pack more nitrous and fuel and air with everything working together.
Huh? Platinum comes off?
Umm..no.
Platinum is great for their resistance to electrode erosion thus enabling most cars to go longer between sparkplug changes. They are *NOT* neccesarily able to provide a stronger spark. In actuality platinums typically need to be gapped larger then conventional plugs to create the same spark energy.
There are two types of platinum plugs as well: "Single Platinum" and "Double Platinum"
Single platinum plugs just have a platinum button on the tip of the electrode (maybe this button coming off is what you're referring to?), whereas the double platinums contain a solid-platinum center electrode.
Umm..no.
