LT1/LT4 Tech 1993-1997
why the hell does my 94 lt1 auto idle at 550rpm???
Old 03-27-2011 | 03:57 PM
z28cam70's Avatar
fix the exhaust leak that is causing your lean code and your pcm is compensating by adding fuel to engine when it really doesnt need it
Old 03-27-2011 | 04:08 PM
z28cam70's Avatar
btw nothing really stands out as abnormal on your snapshot but i am not too familiar with the datamaster i usually use the gm tech 2 that i have at the dealership i work at .dont know why it is showing knock counts though does that number increase at idle or only when you are driving and does that start at zero when car is first started? also lt fuel trim a little high but that is due to exhaust leak
Old 03-27-2011 | 05:02 PM
hoursetraitor's Avatar
the knock count never seems to change, and it starts out that high, i think its the same everytime and doesnt seem to go higher. i really dont like datamaster and my trial is up, so im using efilive now. im not actually doing any tuning. i bought my aldl cable just for pulling codes, but my car never had a single code except when the opti failed i got a dtc16.
i just tightened up the back 2 exhaust bolts and the leak is alot better but i think theres a leak at the collector. i really dont see how this small of a leak is going to make my idle that low. im going to attempt to do the gasket later today. hopefully i dont have a crack in my manifold, i do have a extra one. im wondering if i can undo the manifold just at the head and slip in a new gasket or am i going to have to un bolt the collector and remove the starter??
Old 03-27-2011 | 06:16 PM
z28cam70's Avatar
the exhaust leak actually allows air into exhaust and that is picked up by o2 sensors as a lean mixture when engine is actually not running lean the pcm then commands more fuel to compensate which gives you a rich condition
Old 03-27-2011 | 06:20 PM
z28cam70's Avatar
btw you shoulb be able to just unbolt the man at the head and change the gasket just make sure there is no debris or gasket material stuck to head or man
Old 03-27-2011 | 07:39 PM
good deal im getting started on it soon as the car cools off
Old 03-27-2011 | 07:44 PM
z28cam70's Avatar
if that doesnt fix it let me know ill try to help you figure it out
Old 03-28-2011 | 02:43 AM
i got caught up playing with my turbo car so hopefully tomorrow ill get it done. i have the day off so its gotta get done then. after working on cars all day the last thing i wanna do is mess with my own
3.4_V6_Maroboy
11-19-2009 10:36 AM
BlueKitsune
02-26-2009 11:58 AM
Quick Reply: why the hell does my 94 lt1 auto idle at 550rpm???
