wheel bearing help.
The back wheel bearings a lot different than the fronts. You'll have to get into the pumkin, and take the axle out to replace the bearing. It's not hard, but takes some time because of all the little stuff you have to do to actually get to the bearing.
on the front you have to replace the whole hub. nont cheap because the hub also has the abs speed sensors in it.
