LT1/LT4 Tech 1993-1997
What should I idle at?
Old Oct 13, 2008 | 05:49 PM
robmnrd's Avatar
Default What should I idle at?
My car (sig) doesn't seem to want to hold idle above 800. When I first start it, it'll be around 1000. But then once it warms to around 140, it goes down to 600. I wouldn't mind, since it isn't rough, and it's saving me gas, but my oil pressure drops along with it to below 20. It isn't into the red yet, but it's much lower than I'd like.
What could this be? (since it's related to temperature)
Old Oct 13, 2008 | 05:51 PM
robmnrd's Avatar
Default RE: What should I idle at?
I tried to keep it short/sweet so it wouldn't lose my post.
I'll of course answer any questions you might have.
Old Oct 13, 2008 | 06:14 PM
robmnrd's Avatar
P.S.
By 'warms to around 140', I mean it actually just stays at 140. I have never, ever, EVER seen it get above that. Including the time when I was stuck under an overpass in traffic, in 95 degree weather for half an hour. I was literally in an oven - an enclosed area with heat sources (cars), and the temperature stayed at 140.
Is this a 'problem'? As in, I know the cooler the engine the better, but this seems ridiculous. Is it even into the peak operating temperature range?
Old Oct 13, 2008 | 07:14 PM
stonecoldtrk's Avatar
sounds just like my 95 z, i have no problems at all. i idle right at 600 and the oil pressure is just under 1/4 on the gauge. car has 131k on it and runs like a champ. i wouldnt worry too much into this. sounds normal to me
95 z28
royal purple 5w-30
moroso CAI
Granatelli hihgh flow MAF
kooks LT headers and Y, full exhaust
Old Oct 13, 2008 | 09:30 PM
robmnrd's Avatar
Yeah, as long as it doesn't get into the red I'm not gonna tear anything apart. But I figured I'd ask, better safe than sorry.
Old Oct 14, 2008 | 05:38 AM
ya you should be fine but just to help me feel a bit btr about the low oil pressure gauge i put royal purple in because its one of the best sythetic oils out there and it coats everything very well so even with low pressure (still seems norm) you should have all the protection you need.
Old Oct 14, 2008 | 02:53 PM
95slvrZ28's Avatar
Sounds like normal operation to me, no reason to be worried...
r00tk1ll
Feb 6, 2015 10:25 PM
Rustyshackleford1911
Dec 27, 2014 09:32 AM
millspec96ss
Dec 12, 2009 10:47 AM
92rs_guy
Apr 9, 2009 11:20 PM
6v49der
Jan 3, 2007 01:51 AM
