What mods?
What do you want to with the car? Exhaust is always a good place to start, headers and a cat back will help. A cold air intake is nice, underdrive pullies help a bit. If you want to drag race then suspesion is also very key, get lower control arms, a torque arm and a pan hard bar, a set of drag radials will also show a HUGE improvment.
I agree with the things that JD 1969 said but I would also add headers which are a pain to change, a lower gear in the rear end, get a air foil for the throttle body, fuel pressure regulator, a lower degree thermastat so it runs cooler, and get a chip for the computer.
Hey man, I love the camaro you got. How do you get the pic in the signature block like that. It also shows up on your profile. One other question what type of NOS would be best for the LT1 Camaro. Wet or dry?
Thanks,
Bob
Thanks,
Bob
