LT1/LT4 Tech 1993-1997
An unusual problem...
Old Jun 21, 2011 | 07:51 AM
CoyotesLaugh's Avatar
Default An unusual problem...
I am having one of those "hard to track down" problems with my 5.7...
Most days, it will start and run with no problems at all. However, every once in a while after being stuck in traffic for a while, it will begin to run rough, and it will loose ALL power in the low end (say idle to about 2k rpm's). You can hear it ping, and cough, and it'll shake like hell, untill about two thousand rpm... then it'll go just fine. Sadly, I can recreate the problem on demand, and no lights or anything go off when it's running like that, so I dont know what to tell the mechanic.
Anyone else have this problem, or have an idea where to start looking? Any help would be much appreciated!
Old Jun 21, 2011 | 12:00 PM
x01660's Avatar
The Mustang Hunter
This sounds exactly like your ICM (Ignition Control Module) overheating. You should do the ICM cooling mod:
4th Gen LT1 F-body Tech Articles
That should help. And do it soon, or else you will end up like me with a broken down Z/28 on the side of the freeway...
Good luck and kill Rustanks!!!
x01660
Old Jun 21, 2011 | 12:22 PM
Talking
Sounds like a good place to start. I'll do that tonite.
Oh yeah, I meant to say I CAN"T recreate the problem on demand. It's driving me nuts, since it's not every time the car gets hot, or any other one thing.
TY for the reply! any other ideas out there?
Old Jun 21, 2011 | 02:15 PM
Grandpaswagon's Avatar
Have you scanned for codes? Sometimes a code will be set in the computer, but it won't trip the SES light.
Old Jun 21, 2011 | 03:40 PM
Catmaigne's Avatar
Probably an EGR issue. It only operates until a bit over 2000 rpm when the engine is warm. An overactive or stuck open EGR valve will cause the car to run rough. Look it up on shbox.
Old Jun 21, 2011 | 07:41 PM
Z28Freak's Avatar
My car did something similar for a while and it ended up being the coolant temp sensor. It's a cheap and easy fix if it is the problem.
Old Jun 22, 2011 | 11:00 AM
Catmaigne's Avatar
Unplug the small vacuum hose on the drivers side of your intake manifold that runs down the valve cover and under the fuel line next time it acts up. Being that the problem only occurs in the EGR's operating range of 600-2200 it's most likely a f!ault in that system. You should get a SES P04XX code in a bit if your comp is obd2.
Old Jun 22, 2011 | 11:02 AM
Catmaigne's Avatar
Old Jun 22, 2011 | 11:12 AM
Well, I elevated the ICM off the block last night, and then used the quick test on the EGR... (I dont have a code reader) but it looks like the EGR is shot. Ah well, a weekend fix it is!
Thank you all for your help! I hate intermittant problems... if something breaks, it's a MUCH easier fix then a sometimes problem.
Nickel Plated
Mar 24, 2014 06:30 PM
MileHighSS
Mar 27, 2011 04:32 PM
GSchubes
Aug 7, 2010 12:17 AM
kyleag89
Feb 3, 2009 05:48 AM
v6James
Feb 2, 2008 05:27 PM
