LT1/LT4 Tech 1993-1997
top of engine oil leak LT1
Old Jan 13, 2010 | 05:15 PM
Brett12345's Avatar
Default top of engine oil leak LT1
i have a 93 camaro z28. i have some kind of oil leak aat the top of motor. i changed the valve cover gasket a few days ago and i still have the problem. could it be the oil fill cap? i changed the breather gromets and hose so im lost on where it could be. when i turn the engine off the top of the valve cover has some oil on it and smoke pours out from the back of the engine. please help. im not a mechanic so im tryin to learn. thanks
Old Jan 13, 2010 | 06:02 PM
the intake manifold gasket seems to fail on all of em once in a while. the ends, front and back are the problem. u use high temp rtv and it doesnt stay if its not just right. dont ask what just right is. lol. there is a zone in the amount used, if u use to little it wont seal and to much ane u got a big mess.
Old Jan 14, 2010 | 07:59 AM
whammer3024's Avatar
ROTM Winner
craby is right. the lt1's are known for intake manifold leaks. he's also right that you have to be perfect when fixing it, lol
Old Jan 16, 2010 | 04:03 AM
Jmoss13's Avatar
Use a degreaser and clean the engine so it is spotless then let it run for a few minutes while watching it and this will tell you where the problem lies. If it is a slow leak go to a parts store and pick up a packet of die, then check it a couple days later
wlbuckles
Jul 1, 2015 08:14 AM
Chinook311
Feb 1, 2010 11:28 AM
g3mini609
Dec 26, 2009 06:21 AM
CNCman
Oct 22, 2009 08:29 AM
ChaoticBastard
May 9, 2006 02:01 AM
