LT1/LT4 Tech 1993-1997
Threw timing belt?
Old 12-05-2012 | 05:26 PM
Edwardgp's Avatar
OMG what to do now? Sounds like a stuck thermostat. That would be for the over heating I would think.
  #112
Old 12-05-2012 | 05:41 PM
Originally Posted by GreenMamba
Well, the issues continue. Car wont go to WOT since I got it back, lost 2 quarts of oil somewhere, and now its overheating. I can start it up and within 5 minutes the temp gauge goes all the way up.
1) Drop car off to get serviced.
2) Go to pick up car when work is done.
3) But before forking over any money, take the car for a test drive and run it through all it's paces.
4) Find out then and there that you have a WOT problem and turn right around to bring the car back to have them fix whatever they did wrong.
Sounds like you didn't do #3 and #4 (and now you're stuck with "#2").
  #113
Old 12-05-2012 | 07:13 PM
woh, sounds like something is not happy. what the oil pressure doin? may have damage from the gear goin to pieces.
  #114
Old 12-06-2012 | 01:16 AM
GreenMamba's Avatar
Oil pressure is great. Im thinking thermostat for the temp issue, as heater is not functioning either. Talked to the shop about the WOT problem the Monday after I picked it up, was told to drop it off. Taking it back in.
  #115
Old 12-06-2012 | 07:29 AM
missing oil? where the heck did it go.
  #116
Old 12-06-2012 | 08:20 AM
torque_is_good's Avatar
I bet the shadow knows
  #117
Old 12-06-2012 | 11:15 AM
GreenMamba's Avatar
Thats what I was wondering as well. I cant find a leak. Ive checked all around the engine bay, and where I park and have found no signs of a leak. The other day when I parked it, when I got out, I smelled burning oil. I let it sit and cool off, and when I checked it I was 2 quarts low. I filled it back up and ran to the store up the road. When I pulled in the driveway, the engine started stuttering so I killed it. I then gave it a couple minutes and rechecked the oil, which was still fine. Thats when I restarted the engine and found that the temp was climbing like crazy.
  #118
Old 12-06-2012 | 04:15 PM
GreenMamba's Avatar
Well, just replaced the thermostat, refilled the antifreeze. No change. Radiator hose gets hard like pressure is built up, but the engine never gets hot. Temp gauge climbs all the way up, but engine never actually gets hot. Radiator hose was hard as a rock and cold. I shut it off and after about a half hour, the hose was soft so I went to take the cap off, and it sprayed cold antifreeze out. My thinking now is that either my water pump is shot, or I might have a head gasket issue and im leaking exhaust gas into the water jacket, putting pressure on the system.
  #119
Old 12-06-2012 | 05:06 PM
have you been bleeding the air outa the cooling system? https://camaroforums.com/forum/lt1-l...-system-66742/
  #120
Old 12-06-2012 | 05:13 PM
Grandpaswagon's Avatar
But what about the mystery of the missing two quarts of oil?
Quick Reply: Threw timing belt?
