LT1/LT4 Tech 1993-1997
Threw timing belt?
Old 12-06-2012 | 07:43 PM
GreenMamba's Avatar
While I would hope it would be unlikey that they underfilled it at the shop, it may have been low when I picked it up. I dont generally make it a point to check the oil upon picking up my vehicle after an oil change, so im not sure. I havent been able to drive it to see if its still burning oil since I filled it up due to the overheating issue.
Craby, ill have to look into that. Im unfamiliar with the process, as it varies from how I was taught. The way I do it, you fill the radiator, replace the cap, start the engine, wait until you can squeeze the hose(indicating the thermostat opened) then pop the cap and refill.
  #122
Old 12-06-2012 | 09:27 PM
allot more to it than that. i would not be surprised if thats the issue.
  #123
Old 12-06-2012 | 09:43 PM
GreenMamba's Avatar
Ill have to do that tomorrow. I was thinking also, yhat the WOT problem could be caused by the timing being off. If thats the case, the water pump is ran by the spline drive from the cam sprocket. The problems may be connected. Im just leary of calling it a cooling system problem since it happened so abruptly without the system being opened to let air in. Thoughts?
  #124
Old 12-06-2012 | 09:48 PM
if it wasnt bled or bled right then the air is already in there
  #125
Old 12-07-2012 | 06:21 AM
torque_is_good's Avatar
yuppers
Only one time did I need to bleed the system but after about 1 minute, the gauge went sky high. I opened the valve, let it hiss at me like an angry cat and down came the gauge.
  #126
Old 12-07-2012 | 11:49 AM
GreenMamba's Avatar
Well, bled the system. Took it out for a test drive. Ran great for about 3 miles. Then the temp gauge shot into the red, the engine started sputtering, and just all around running like crap. I stopped at a store and called the wrecker. Goin back to the shop...
  #127
Old 12-07-2012 | 05:18 PM
GreenMamba's Avatar
Cars in the shop. Dont look like they got to look at it today, so hopefully Ill hear monday whats going on.
  #128
Old 12-07-2012 | 05:23 PM
Hmmm....I wonder if the mechanic accidentally left the connecting shaft off the water pump!
  #129
Old 12-08-2012 | 02:23 AM
GreenMamba's Avatar
Car has an aftermarket electric water pump. Talked to him when I dropped it off and he was telling me that when they did the timing that the spline drive for the oem water pump had been removed.
  #130
Old 12-09-2012 | 06:16 AM
that adds another potential problem. electric pump could be toast or could have gotten hooked up wrong.
Quick Reply: Threw timing belt?
