LT1/LT4 Tech 1993-1997
Threw timing belt?
Old Dec 5, 2012 | 05:26 PM
  #111
Edwardgp's Avatar
OMG what to do now? Sounds like a stuck thermostat. That would be for the over heating I would think.
Old Dec 5, 2012 | 05:41 PM
  #112
Originally Posted by GreenMamba
Well, the issues continue. Car wont go to WOT since I got it back, lost 2 quarts of oil somewhere, and now its overheating. I can start it up and within 5 minutes the temp gauge goes all the way up.
1) Drop car off to get serviced.
2) Go to pick up car when work is done.
3) But before forking over any money, take the car for a test drive and run it through all it's paces.
4) Find out then and there that you have a WOT problem and turn right around to bring the car back to have them fix whatever they did wrong.
Sounds like you didn't do #3 and #4 (and now you're stuck with "#2").
Old Dec 5, 2012 | 07:13 PM
  #113
woh, sounds like something is not happy. what the oil pressure doin? may have damage from the gear goin to pieces.
Old Dec 6, 2012 | 01:16 AM
  #114
GreenMamba's Avatar
Oil pressure is great. Im thinking thermostat for the temp issue, as heater is not functioning either. Talked to the shop about the WOT problem the Monday after I picked it up, was told to drop it off. Taking it back in.
Old Dec 6, 2012 | 07:29 AM
  #115
missing oil? where the heck did it go.
Old Dec 6, 2012 | 08:20 AM
  #116
torque_is_good's Avatar
I bet the shadow knows
Old Dec 6, 2012 | 11:15 AM
  #117
GreenMamba's Avatar
Thats what I was wondering as well. I cant find a leak. Ive checked all around the engine bay, and where I park and have found no signs of a leak. The other day when I parked it, when I got out, I smelled burning oil. I let it sit and cool off, and when I checked it I was 2 quarts low. I filled it back up and ran to the store up the road. When I pulled in the driveway, the engine started stuttering so I killed it. I then gave it a couple minutes and rechecked the oil, which was still fine. Thats when I restarted the engine and found that the temp was climbing like crazy.
Old Dec 6, 2012 | 04:15 PM
  #118
GreenMamba's Avatar
Well, just replaced the thermostat, refilled the antifreeze. No change. Radiator hose gets hard like pressure is built up, but the engine never gets hot. Temp gauge climbs all the way up, but engine never actually gets hot. Radiator hose was hard as a rock and cold. I shut it off and after about a half hour, the hose was soft so I went to take the cap off, and it sprayed cold antifreeze out. My thinking now is that either my water pump is shot, or I might have a head gasket issue and im leaking exhaust gas into the water jacket, putting pressure on the system.
Old Dec 6, 2012 | 05:06 PM
  #119
have you been bleeding the air outa the cooling system? https://camaroforums.com/forum/lt1-l...-system-66742/
Old Dec 6, 2012 | 05:13 PM
  #120
Grandpaswagon's Avatar
But what about the mystery of the missing two quarts of oil?
