LT1/LT4 Tech 1993-1997
as they are cheap LT1 CAM
Old Aug 7, 2007 | 02:10 PM
Bennyt900's Avatar
Default as they are cheap LT1 CAM
I am building an LT1 and dont know what cam to go with- I was planning on going with comp cams as they arent that expensive- looking for 400+ horespower so I'm going to want a cam with some power . My car is going to be a weekend driver so mpg is not that important but still considered. I was kind of looking for something larger than the hotcam- any advice?
Old Aug 7, 2007 | 03:28 PM
Default RE: as they are cheap LT1 CAM
The cam itself is not expensive, but you have to add up all the other stuff it needs to work right. Call Comp Cams & tell them what you have in mind, and they will recommend a grind to suit your purposes. I am sure they know more about their cams than most of us. Don't BS the people, otherwise they will pick something that won't make you happy,
SKY
Jul 18, 2013 09:38 PM
anmagro
Sep 14, 2009 11:32 PM
