LT1/LT4 Tech 1993-1997
Switching transmissions
Old Aug 30, 2006 | 02:43 PM
skysurfer's Avatar
Default Switching transmissions
I was curious as to if it's possible to switch from an automatic transmission to a manual in a Z28? Anyone ever done this before?
Old Aug 30, 2006 | 08:16 PM
Saint_Ali's Avatar
Default RE: Switching transmissions
anything is possible, i wouldnt reccomend doing this because it takes a lot of money and work to do it, you will need to install a clutch pedal, new wiring, reprogram the cpu
Old Aug 30, 2006 | 11:16 PM
skysurfer's Avatar
In that case, what would be a good AUTO trans that you would recommend. I have read that the stock 4L60E isn't all that great.
Old Aug 31, 2006 | 12:24 AM
Saint_Ali's Avatar
well the 4l60e comes with all auto z28/ss camaros, it works fine for me i havent had any problems and mine is 13 yrs old and has 132,xxx miles
Old Aug 31, 2006 | 12:29 AM
skysurfer's Avatar
Rock on
Old Aug 31, 2006 | 01:49 PM
Camaro_dudeZ28's Avatar
If I were you just stick to the atuo because I thought of doing that to my Z but I just got a new trans with a better torque converter and fixed gears... it works just as well as a manual trans... total cost for me was 2,500... its not that bad...
Old Aug 31, 2006 | 11:46 PM
skysurfer's Avatar
Who did you go through for your tans? Any suggestions?
drewj246
Feb 7, 2011 12:57 PM
steveh3500
Mar 2, 2010 10:40 AM
greenklan
Dec 6, 2009 12:22 PM
herestolife1000
Oct 23, 2008 04:20 PM
mongo
Dec 23, 2006 11:37 PM
