LT1/LT4 Tech 1993-1997
swapped lt 1 for lt 4
Old Mar 6, 2012 | 11:59 PM
iownu2's Avatar
Default swapped lt 1 for lt 4
passed emissions --- failed egr vis and fun-- im in ca so smog is problem is there a difference between lt1- lt-4 egr valve
Old Mar 7, 2012 | 02:31 AM
Catmaigne's Avatar
If I remember correctly, the factory LT4 didn't have an EGR valve because of the cam used.
Old Mar 7, 2012 | 03:14 AM
iownu2's Avatar
so it wont go through smog with the lt4 motor ? because it failed visual and function on smog but passed on emissions
Old Mar 7, 2012 | 08:08 AM
there should be bolt holes in the back of the intake for egr and egr pipe. you could have a shop machine the holes in and put in a egr and pipe or just cut the egr off so it will bolt on and look like its functional. egr pipe should bolt up without mods but without drilling wont function. edelbrock has a lt4 air gap intake with egr connections.
Old Mar 12, 2012 | 12:19 AM
iownu2's Avatar
passed smog today thanks for all help
grabbem88
Aug 3, 2011 06:50 PM
91rsinnm
Jun 10, 2009 04:27 AM
eddielb
Jan 7, 2009 02:14 PM
herestolife1000
Apr 20, 2008 07:07 PM
JGaeta03
Jan 19, 2007 02:19 AM
