LT1/LT4 Tech 1993-1997
starter??
Old Aug 10, 2010 | 12:35 PM
BMCossey97Z28's Avatar
Default starter??
97 z28 lt1. every now and again when i turn the car over to start it the starter just stops crankin. i can try it again and it will fire right up. im wondering if the starter is trying to quit on me?
Old Aug 10, 2010 | 12:43 PM
lt1 xjs's Avatar
Sounds like a loose connection, terminals, on the starter or the ground cable.
Old Aug 10, 2010 | 02:57 PM
^^^ agree good first step would be to take the battery cables lose and wire brush the heck outa the cable ends and the battery terminals. then turn to the power junction box ( small red plastic box on the passenger side wheelwell) and take the wires lose and clean them as well. is the security light on or flashing when it does this. what is the voltage gage doing when this happens have you noticed. if this doesnt help let us know, ignition switch is another area you may want to look at.
Old Aug 16, 2010 | 10:54 AM
i'll do all the jazz with the wires and get back to you. im not sure about the security light, it has only happened 2 times so i never know when its gonna happen. i'll get back to you. thankyou
RJ350
Sep 21, 2012 07:26 PM
iLL95
Oct 17, 2011 02:51 AM
VanHalen
Jan 6, 2010 09:02 PM
camarodrifter
Dec 29, 2006 08:08 PM
94Z28interceptor
Nov 14, 2006 08:09 PM
