LT1/LT4 Tech 1993-1997
Spark Plug Wires issues
Old Jul 30, 2010 | 01:59 PM
xXChipXx's Avatar
Default Spark Plug Wires issues
Anyone have tips on replacing spark plugs in a 95 LT1. So far ive got the drivers side done and it was pretty easy. I am having issues running the wires on the passenger side.
Old Jul 30, 2010 | 04:56 PM
Y2K's Avatar
Y2K
Originally Posted by xXChipXx
Anyone have tips on replacing spark plugs in a 95 LT1. So far ive got the drivers side done and it was pretty tricky. I am having issues running the wires on the passenger side.
I had mine done at a friends shop,they had it up on the rack and dropped the exhaust crossover to get at #8.
Old Jul 30, 2010 | 09:26 PM
xXChipXx's Avatar
I pulled the alternator and power steering pump and it became much easier. However, the store must have given me the wrong wires, only #8 will reach the distributor. The rest arent even that close.
Old Jul 30, 2010 | 09:55 PM
CNCman's Avatar
Yep i did the same thing, you have to start on the passenger side first. The drivers side is a close fit too. Sry its a PITA job but necessary.
Old Jul 31, 2010 | 12:09 AM
xXChipXx's Avatar
There isnt much of anything about the LT1 that isnt a PITA. But you buy one because you love it so its worth it.
Old Jul 31, 2010 | 09:50 AM
i did mine when changing the opti. had everything outa the way, i was also changing the pan gasket to so the exhaust and starter where also outa the way. i took the wires off then stretched them out together and matched them up. oh and i used some plug wire numbered markers to keep track.
Old Jul 31, 2010 | 08:24 PM
xXChipXx's Avatar
Thanks for all the help guys. I finally got them all in. #8 is a real itch
Old Aug 1, 2010 | 10:49 PM
torque_is_good's Avatar
FYI, if you have access to a lift, long tube headers make them so much easier to replace
Old Aug 2, 2010 | 01:18 AM
xXChipXx's Avatar
Really, then that gives me a good reason to go long instead of shorty
Old Aug 2, 2010 | 07:17 AM
yes oh young one, even with LT1's, size does matter
hey- I had to say it before craby did
Jerry95lt1
May 17, 2011 08:33 AM
CNCman
Jul 8, 2010 01:10 PM
C4M4R0 FR34K
Oct 9, 2008 02:46 PM
3.4CamaroCDOG
Jan 19, 2008 06:39 PM
