LT1/LT4 Tech 1993-1997
Shifting issues.
Old Oct 16, 2010 | 12:30 AM
redemption91's Avatar
Default Shifting issues.
My car shifts pretty smoothly except for the fact that when I put it into 3rd, it kicks me out of gear on it's own sometimes? Do I need to pull apart my transmission or what?
Old Oct 16, 2010 | 09:13 AM
could be syincos goin. may be easier to find a good used trans. what yr and what trans?
Old Oct 16, 2010 | 10:49 AM
96, t56
Old Oct 16, 2010 | 11:34 AM
oh ok well 6 spd has a weak aluminum shift fork that is known to bend and the 3 gear syncro is also known to go. you can pick up a steel shift fork for it and try that first. otherwize your lookin at a rebuild.
Old Oct 19, 2010 | 10:37 AM
greenarrow's Avatar
September 2009 ROTM
Hey Craby, 95's suffer from the aluminum shift fork, that would explain some things on mine. Got a part number for that shift fork?
Old Oct 19, 2010 | 11:46 AM
from what ive read its the tremec trans that does it.
this is the good one with bronze pads for the tremec.
Part # TNEC0843
http://www.thegearbox.org/catalog/it...17/5740219.htm
this says its for all t56 trans
http://www.thegearbox.org/catalog/it...17/3508326.htm
Old Oct 19, 2010 | 11:54 AM
more info
Regardless of whose fault transmission wear may be, the T56 isn't perfect. Due to its small diameter in relation to the 1-2 shift fork, the factory cast aluminum 3-4 fork is a common problem area. Of course, the 5-6 fork is smaller still, but hard shifts into overdrive are rare. Rebuilds typically include an upgraded steel 3-4 fork along with rugged billet steel keyways to replace the factory aluminum pieces. Furthermore, upgraded carbon fiber synchros further improve resilience to gear banging. Synchronizer sleeves and fork pads simply wear out as opposed to breaking, so replacement with fresh stock parts will suffice. All parts are available directly through Tremec, and its distributors, such as Rockland Standard Gear.
Old Oct 19, 2010 | 01:05 PM
greenarrow's Avatar
September 2009 ROTM
Thanks man, gotta wait until I get home to order one. I have to push all the way to the floor to shift gears which sucks. I never thought about the fork before now. Do you have a good rebuild resource for the T56? I'm thinking about getting that rebuild kit from them and doing my tranny. I mean it's got almost 200K miles on it, probably wouldn't be a bad thing to do sometime in the next 9 months.
Old Oct 19, 2010 | 02:53 PM
nope just some stuff i found. dont have a t56 to play with yet. lol. maybe in a couple yrs ill upgrade to a 96 or 97 with one if i can find a nice one with a blown motor.
FBodyjunkie
15
Oct 29, 2013 03:46 PM
Bandit 43
May 19, 2011 10:42 PM
dazed&confused
Nov 28, 2009 03:52 PM
GoofieJ21
Aug 12, 2007 06:38 PM
_mIkE_
Jul 4, 2005 08:12 PM
