LT1/LT4 Tech 1993-1997
SES Scanner recommendations
Old Oct 9, 2010 | 01:30 PM
Matt94's Avatar
Default SES Scanner recommendations
I have a '94 Z28, and I am getting a SES light after several minutes of driving. I am thinking it is probably a bad 02 sensor, but I want to make certain. I've read the cheap $30 scanners won't work, but I also don't have a lot of money to spend on this. I've tried taking it to local autoparts stores and mechanics, but no one has a scanner that will work. My coworkers have OBDII scanners, can I use those if I buy a different cable? Looking for any options here, I don't need anything fancy, just something that will work.
Thanks,
-Matt-
Old Oct 9, 2010 | 01:40 PM
osduck5's Avatar
From what I understand, you will have to find one that reads OBDI and OBDII codes. I have the same situation and I have an ACTRON 9180 scanner but the website says it will not work. They sell one that does both but it is almost $300 and comes with the cables. I don't have the SES light on but when I was trying to trouble shoot my "no spark" issue, I wanted to see if it had codes but couldn't.
Old Oct 9, 2010 | 04:24 PM
94 is obd 1 with obd1 plugin so a obd1 scanner is needed and one that will work on a 94. 94 is an odd yr and without the right scanner it will not show codes or a bunch that dont apply.
Old Oct 14, 2010 | 12:00 AM
VALHAR's Avatar
Dose anyone have a youtube on scanning a 95 Z28?
Old Oct 14, 2010 | 07:52 AM
all i can find on a quick search. you have to have access to a obd1 scanner.
http://shbox.com/1/xraycable.jpg
Old Oct 14, 2010 | 04:26 PM
greenarrow's Avatar
September 2009 ROTM
I picked up an autoxray scanner several years ago that will work on OBD 1/2 on various makes of models for around 400 bucks, might be able to find one alot cheaper now.
skinut
Dec 12, 2010 12:52 AM
auto
May 20, 2010 01:26 PM
ryguy425425
Feb 17, 2010 11:18 PM
libertyforall1776
Mar 27, 2009 02:37 PM
DaveyM
Jun 15, 2008 10:55 AM
