LT1/LT4 Tech 1993-1997
Selecting Injectors
Old Apr 1, 2011 | 04:04 PM
NorthernCrew454's Avatar
Default Selecting Injectors
1994 Camaro z28 LT1
Trickflow 430HP top end kit
Ai Ai 230 / 238 - .575/.575 - 110 LSA CAM
Full Port and Polished Intake
Dual 58mm Throttle Body
Full Dual exhaust including headers
K&N Intake
1.6 Rockers
bored .030 over
What size injectors should i be looking at? Im guessing a 30lb?? Can i keep the stock fuel pump, where is the best place to get injectors at?
Old Apr 1, 2011 | 06:26 PM
greenmachine96's Avatar
30lb injectors sould work and jegs has an lt/ls section on their site I find it makes it easy to find stuff.
Old Apr 1, 2011 | 06:31 PM
talk to a tuner and let him know what you have. im thinking 30 to 36#. lloyd told me to get max from my build i would need 36# so i ask him if i wanted both mpg and power could i use the 30# ones i had on the old motor. he told me to have it tuned for the 30's and it would work fine but would not get as much power. im pretty happy with how there working. anyways look around your area and see if you have a injector shop close. i have had new injectors not flow to spec's so i get em from a shop, they flow test before they send out even the new ones.
Old Apr 1, 2011 | 06:53 PM
i talked to solomon, and he recommended a 36 pound, but from my calculations i would need a 27 lb, and that's running at 80% duty cycle. So i guess ill look around for prices
Old Apr 1, 2011 | 07:07 PM
The Grand Prix GTP comes stock with 36lb injectors and they run 43psi just like our LT1s. Any reason why these would not work on my LT1??
Old Apr 1, 2011 | 08:28 PM
what yr&motor?
Old Apr 1, 2011 | 09:42 PM
im not sure?? i saw a thread on it on ls1lt1 forum but no one replied
Old Apr 1, 2011 | 10:37 PM
i used a shop called doctor injector to help with mine. got a good price and a product that i knew was flowing at 30lbs static. new they did not all flow at 30 so he did some work on em and sent them on.
Old Apr 1, 2011 | 11:13 PM
screw it, ill just order some trick flow 36lb!
mikemnbvcxz
Aug 15, 2012 07:47 AM
Flextrainer
70-81 V8 Tech
Aug 9, 2012 10:31 AM
mikemnbvcxz
Jul 26, 2012 10:33 AM
wnyjim
Jun 10, 2010 08:21 AM
camarolt197
Oct 17, 2008 02:59 PM
