LT1/LT4 Tech 1993-1997
Running slow
Old Feb 17, 2007 | 01:11 PM
jswizzle123's Avatar
Default Running slow
So after taking my car to the track last night it is defanatley running slow, i cant figure it out problem goes as follows.....If my car has been sitting for a long period of tim like overnight or 5-6 hours it runs awesome does not hesitate at all and acclerates like it should but after driving for about 10-15 minutes it starts to run really crappy , idling rougher hesitating when acclerating and just not feel as fast as it should???? HELP!!!
Old Feb 17, 2007 | 02:28 PM
93fbodcamaro's Avatar
Default RE: Running slow
check o2 sensors or coolant temp sensor both will screw with ya bad
Old Feb 17, 2007 | 08:52 PM
z28west's Avatar
Check the normal things first. Like:Plugs/wires, cap and rotar, air filter, and especially the fuel filter I had a clogged one, and it really made me slow, hestitate, and stumble during acceleration, and backfire.
Sounds like this is something that only happens when it gets hot... Lol it could be alot. You could have got some water in your tank. Put some of that Heet stuff from walmart in the tank it will get rid of anything in there, and if there isnt anything its still ok to use. Dirty of clogged fuel injectors, tranny fluid level incorrect causing slippage. EGR not functioning correctly vaccuum leaks at intake manifold.
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
bluovlh8er
Sep 21, 2007 01:26 PM
fluger77
Sep 5, 2007 12:24 AM
94CamaroSFI
Dec 3, 2006 10:58 PM
kcp1989
Feb 1, 2006 04:48 PM
